Last edit by: IB Advertising
- Chevrolet Silverado 2007-2013: How to Install Air Suspension
Step by step instructions for do-it-yourself repairs.
rear suspension noise/shock question
ok I have a 2007 Tahoe LT with 48000 miles - it really sounds like the rear shock may be going out or at least making the noise I am talking about. I have not noticed it in the past because the Tahoe lives on the pavement usually but last weekend we went to our land and I drove around the trails. Every bump I could hear a pretty loud grinding/rubbing noise that went with every bump especially when going downhill or not pushing the gas.
I posted this earlier https://chevroletforum.com/forum/tahoe-suburban-25/clunk-noise-when-stop-start-2007-a-31037/ I have been too busy to go by the dealer yet...but another thought is the noise was not there very much if at all when I was going up a hill/pushing the gas. Maybe something is just loose and when going uphill/pushing the gas it loads it enough to hold it tight?
what is the normal lifespan for the stock shocks? Should I go with OEM or is there another good aftermarket brand that provides a similar ride?
I have worked on most of my other cars myself but I have not had much time to really "get to know" the Tahoe.
thanks for any help
thanks for any help
If you have not already climbed under the vehicle, I'd start there and see if anything obvious.
As for shock replacement, I think I read somewhere that the 40-60K mile range or about 3-4 years old is the time to look at replacement.
If you do them, do all 4 corners, I have used KYB in the past on my 97 Tahoe and they rode well. I have not replaced the ones on my 07 Tahoe yet...but will consider it when I hit the 45k mark
I have a 2007 Tahoe LT 2wd with 31,000 and when I go over a speed bump slow of enter a drive way etc it sounds like my rear shocks or something else in the rear suspension is bottoming out, it makes a pretty decent squeak. Should the OEM shocks be bad this early? Im wondering if i should just go ahead and take it to the dealer while i still have some factory warranty left? I have never had an SUV yet so I'm not sure if this is normal.
When im going slow and I brake and go over a bump it almost seems like im peeling out, its like an errr on pavement or something. LIke I did a little spin out or something. It may not even be the shocks. I guess I will bring to the dealer this week.
mine sounds like a squeeky bed or something like that when going over a big bump. the truck handles just fine and if I try to jump on the back bumper it settles just like normal - not obvious that a shock is going out or anything but it very well could be or something rubbing.
I would have to agree with 73Shark's assessment to have your vehicle looked at at the dealership. You've said that you still have some warranty left (and by the miles you do) so if you've still got it use it before you lose it.
Jeff Morris, Chevrolet Customer Service
some squeaking and or squealing sound can come from the upper shock tube cover scrapping on the shock tube body, however the 07's have a plastic upper cover so this is probably not the issue.
What can also make the sounds is the drive shaft splines getting dry and needing to be lubricated. GM has a lube product that can be safely be applied to the drive shaft splines and won't contaminate the transmission hydraulic fluid.
Ask the dealer to lube the drive shaft splines, this will also address any clunking sounds you have when you come to a stop...
Thanks for all the replies. I know that drive shaft deal because my 07 silverado did the same thing and they had to lube the shaft. I don't know what the sound is comming from but the ride is not hurt. I'm going to go ahead and bring it in tomorrow.
It may be helpful if you can take them for a ride so you may be able to better duplicate the circumstances that it happens under, otherwise don't be surprised if you get your truck back with about 20 more miles on the odo and a no issues found results and possibly the faint smell of breakfast taco's in the truck road trip... (just kidding) but really drive it with them if you can...
