Service 4wd/TCCM Repair?
Old Dec 11, 2022 | 10:34 PM
Lanetrain's Avatar
Default Service 4wd/TCCM Repair?
Hey guys,
long time lurker but first time poster. I have a 99 GMC suburban 5.7 335k miles NP8. I live in North Dakota and I've recently been getting a service 4wd light on the dash seemingly when the temperature is below freezing. Scanned the code with a snappy scanner at work and came up with a c0367 (front axle control circuit high). When the service 4wd light is on selecting any mode but 2hi results in that selection flashing and no shifting.
I have a basic Bluetooth obd code reader that I can use to clear the code. Once the code is gone I shift into whatever mode I wish. It seems like the code appears when I park the vehicle in 4wd. ​My questions are: do I just replace the TCCM and call it a day? If so should I try my luck on a used module? Or is it possible to dissemble the module and resolder some connections? I wouldn't mind trying to open the TCCM up, but I have no idea which connections would need to be soldered. I've searched the forums and Google extensively and it has led me here. Thanks in advance
Old Dec 11, 2022 | 11:12 PM
Welcome to the forum.
Old Dec 12, 2022 | 7:59 AM
repairman54's Avatar
Back when I had my old '99 Yukon the motor on the front axle that shifts it was a common issue back then.
fsxbob
12
Jul 21, 2021 10:44 PM
BMWFan
Jul 8, 2021 8:22 AM
Hilmar Hardarson
Oct 30, 2018 10:45 PM
04BLK8.1
Jan 4, 2016 9:59 PM
oldtruckgoodtruck
Apr 28, 2012 11:13 PM
