Squawks and Resistance
Old Sep 24, 2011 | 1:49 PM
SWHouston's Avatar
Default Squawks and Resistance
I haven't had my Burb all that long, and don't have any experience with the Transmission Operations on it. I have the 4 Speed Automatic, with the Electronic "Buttons" which move it into 4WD.
When I have it in 2WD, it runs smooth as silk, but...
when I put it in 4WD, the Front Axle seems to totally lock, and I get squawking from the inside wheel on a turn, and if it let up on the gas, it is like putting the brakes on it stops so quickly. That's when I'm turning, but it drives ok in a straight line in 4WD.
I believe/know that I have the Positrack, but, I thought that was in the Rear Differential not the front. What's causing this front wheels "lockup" ?
Old Sep 24, 2011 | 3:37 PM
kevinkpk's Avatar
What type surface are you driving on?
Old Sep 24, 2011 | 7:09 PM
SWHouston's Avatar
Thank you for your reply...
It doesn't seem to matter, Pavement, Rock, Dirt, I can hear/feel the inter front wheel of the circle, trying to keep up speed with the outer wheel, in either direction I turn.
IF the Front Axle has Spider gears in it, shouldn't they allow the different wheel speeds to occur, just like a standard rear end does ?
It's just like the Spider gears were frozen, or IF there's any kind of Traction Control up there, that it's got both front wheels stuck/locked together.
Old Sep 24, 2011 | 7:52 PM
kevinkpk's Avatar
I don't know, but if you're driving it on dry pavement it will display your symptoms especially in a trun. I thinks because of the "slip" in the front diff.
Old Sep 24, 2011 | 8:40 PM
SWHouston's Avatar
But, there is NO slip in the front differential !
Those wheels are solidly locked, and that is going to cause some excessive wear on my front tires. Are you sure this is normal/intentional ! ?
Old Sep 24, 2011 | 8:53 PM
Every 4WD I've driven does what you describe on dry, hard surfaces.
Old Sep 24, 2011 | 9:11 PM
kevinkpk's Avatar
Bottom line, if not in 4x4 conditons, don't drive in 4x4.
Old Sep 24, 2011 | 9:13 PM
kevinkpk's Avatar
You'll have a limited slip in the front diff, and in the rear unless it is a posi track. When turning the front (in 4x4) every 4th or so (not sure) revolation it will "drive" that wheel.
Old Sep 25, 2011 | 3:22 PM
mercracing's Avatar
All four wheel drive vehicles are actually "three wheel drive" unless there is a locker in the back. When you put it into four wheel drive you lock the front and thats why you get the noise during the turn, because the wheels are locked together but they are trying to turn at different speeds.
Old Sep 25, 2011 | 4:39 PM
SWHouston's Avatar
Well crap !, I'm not sure if I like that or not !
(the way it works, not your replies )
I guess it's a real advantage to have the Front Wheels locked together when you really need the traction, but it sure seems like it's not a good idea, when you're turning, seems like they would have put some sort of slip feature up there, where they would stay connected to the surface.
I have the G80 Rear setup, but is that a Limited Slip, or a Positrack ? I know it "recognizes" the need for different wheel speed on turns.
