Steering wheel play on 2003 Suburban
Old Jan 14, 2007 | 7:41 PM
CPUFed's Avatar
Default Steering wheel play on 2003 Suburban
I'm looking at buying at 2003 Suburban and have it for the weekend. When I turn a corner slowly and over bumps I can feel a slight play in the steering while, kind of like a knocking. Any ideas?
Old Jan 14, 2007 | 11:48 PM
golfer's Avatar
Default RE: Steering wheel play on 2003 Suburban
Tie rods ??
Old Jan 16, 2007 | 5:46 AM
ndoddchevy's Avatar
Hi,
I have the same problem with my 2003 Suburban K1500 LT 4x4 - however two different workshops cannot find anything wrong, loose or worn.
Does anybody have any other ideas?
Old Jan 18, 2007 | 10:16 PM
RoadWarrior03's Avatar
It's a minor service. You need a lube kit applied to the steering column. I have it done once a year or so.
No big deal.
Old Jan 20, 2007 | 1:20 AM
CPUFed's Avatar
That was the problem. I had theservice managertake a ride in it beforeI bought it and he knew exactly whatthe problem was. The service dept. applied the lube kit and it's fine now.
Old Jan 29, 2007 | 5:05 AM
ndoddchevy's Avatar
Where exactly do you apply the lubrication?
Most workshops in the UK are not familiar with this make or model.
I have the workshop manual so if anyone is able to refer to a chapter, page number or illustration that would be a great help.
Old Aug 27, 2007 | 4:20 PM
ndoddchevy's Avatar
Any feedback on the exact lubrication points?[/align][/align]Its been 8 months....[/align]
Old Aug 28, 2007 | 8:42 PM
bpdcpa's Avatar
Hello. I have an '02 Suburban and had the same problem several years ago. I took it to the dealer, and they said it was actually a recall issue.I don't remember exactly what they did, but I am sure it was beyond lubricating. You may want to check into a possible recall?
Old Aug 29, 2007 | 3:44 PM
ndoddchevy's Avatar
Thanks - any idea what the recall number was or is anyone else familiar with this recall?[/align][/align]Unfortunately I am in the UK and I don't think that a recall note would be effective here [].[/align][/align]Cheers[/align]
Old Aug 31, 2007 | 12:00 AM
jepeters's Avatar
[align=left]I have the same issue. With a front wheel jacked, I can move the tire back and forth ( left and right ) about 1 inch. The other tire is stationary. I asked a repair shop and they jumped into telling me that the tie-rods are shot. Also, the inside of the pass tire is wearing down faster then the other side. I'm bringing it in over the weekend. I'll ask about the lube kit.
I'll post later next week what the results are....
[/align]
