TBI Runs Lean & Hesitates When U Accelerate
Old Dec 11, 2011 | 7:52 PM
pos95suburban's Avatar
Angry TBI Runs Lean & Hesitates When U Accelerate
My 95 Suburban is running lean and has hardly any power when I push on the gas, it hesitates and also dies sometimes when I am stopped at lights. It always starts up and it idles fine in park and neutral, but when it is in drive and reverse it tries to die if you don't give it gas it usually will die. I have replaced the map sensor, iac valve, tps, fuel filter, O2 sensor, I have also checked all of my vacuum lines and they are good, the Egr valve is only a year old same with the plugs, wires, distributor cap and rotor.
Please Help.
Old Dec 11, 2011 | 7:56 PM
MDTAHOE's Avatar
Professional Mechanic
How do you know it is lean?
Old Dec 11, 2011 | 8:25 PM
It smells lean.
Old Dec 11, 2011 | 9:02 PM
MDTAHOE's Avatar
Try unbolting the exhaust in front of the cat and drive it. Does it act the same way.
Old Dec 11, 2011 | 11:01 PM
I will try it, but the cat is only a year old also.
Old Dec 12, 2011 | 6:04 AM
shamrock246's Avatar
what's fuel pressure?
Old Dec 12, 2011 | 9:40 AM
How can I check the fuel pressure?
Old Dec 12, 2011 | 9:38 PM
MDTAHOE's Avatar
Fuel pressure spec for that truck is 9-13 psi. It is a possible cause for the problem but not likely. Those pumps pretty much died completly since the pressure is already low, it is hard to go from almost no pressure to less. There is no fuel pressure test port you must tie into the lines and have a gauge that can read accurate at that low pressure. A couple of psi will make a difference using a cheap gauge
Old Dec 12, 2011 | 9:46 PM
MDTAHOE's Avatar
It could have a bad ignition coil or pick up coil. Still more likely than fuel pump.Exhuast could smell funny because it is not running correctly
Old Dec 14, 2011 | 7:02 PM
I think the intake manifold gaskets need to be replaced, i'm going to replace them I will let you guys know if this fixes my problem.
