View Poll Results: Do you regularlly use Techron
Voters: 12. You may not vote on this poll
Techron, do use it regularly
So I picked up a case ( 6 bottles) of Techron Concentrate Plus 20oz
Open up the box and read the label and it says to use it every 3k miles.
Somehow I got it in my head that it only needed to be used about every 10k.
Anyone else use it regularly?
Also there are different bottle sizes notice that the size ounce size corresponds to the gallons at fill up 12oz= 12 gallons 20oz= 20 gallons at fill up. car size and truck size I'm guessin
I know if you go to the dealership for regular maintenance, they recommend a fuel additive as well as an oil additive, I'm going to guess that the fuel additive is probably Techron or GM's version of it, anyone know what the oil additive is?
and what additive could the use that isn't already in a fully synthetic?
I just got a bottle of 20 gal Techron treatment at the auto store tonight. I am still getting some power loss when at 60%-100% throttle between 3,000 & 4,000 RPM's, almost like a secondary valve isnt opening but theres only one on my throttle body. Its not triggering any codes with this problem so I will see if the $12 bucks of Techron helps at all.
In the last few weeks I have changed the , plugs, wires, fuel filter, air filter, cleaned TB, cleaned MAF, carefully cleaned o2's<--(do that at your own risk!), changed PCV & Joined the royal purple club oil change. I idles and sounds alot cleaner and smoother but still that little power problem.
Interesting..
here's the link for BG products
http://www.bgprod.com/products/products.html
The MOA has some pretty good claims to it
