Thoughts on Head Gasket Sealant
Old Apr 11, 2020 | 5:37 PM
Greg Guess's Avatar
Default Thoughts on Head Gasket Sealant
99 Burb 5.7 that h
Something like this
as 288k on the clock. Noticed it has begun to loose a little antifreeze. Not quite 1 quart per 1000 miles. Never runs hot. Does put out some white smoke on cold starts then quits. No bubbles in the radiator or resivoir, but rented a head gasket tester from the parts store and the antifreeze tests positive for exhaust gasses.
Anyway, should I try a head gasket sealer like bars or wait to see if the problem worsens. My thoughts are try $30 to see if it helps before a tear down sometime in the future.
Old Apr 11, 2020 | 5:53 PM
Little Bear's Avatar
IMO the sealers are a last option, if they do work it isn't for long, if you can fix it right and keep going.
Old Apr 11, 2020 | 6:00 PM
kevinkpk's Avatar
Nope, head gasket in a can or whatever, this isn't a fix.
Old Apr 11, 2020 | 8:32 PM
snake oil
Old Apr 12, 2020 | 7:27 AM
They work but not for long. I used it once and it lasted for about 6 months. I guess it depends on how bad the leak is.
Old Apr 12, 2020 | 7:46 AM
sfcjones's Avatar
I wouldn't use it at all.
That stuff is nothing but a short term fix with long term issues.
Old Apr 13, 2020 | 9:12 AM
repairman54's Avatar
I'll add that any sealer in the cooling system will plug heater cores and radiators sooner or later.
Old Apr 13, 2020 | 9:24 AM
kevinkpk's Avatar
Also, if it does seal, i,e, radiator, it will find the next weak spot, and leak there.
Old Feb 2, 2021 | 11:45 AM
MIKEY BARAN's Avatar
I Have Used Sealer In My Older Spare Vehicles...If You Follow The Instructions, And Its A Small Hairline Crack...IT WORKS ...Add It SUPER SLOW ...If You Just Dump It In, You Can Expect Clog Issues...Try FIBERLOCK BY K&W....You Will Feel And Hear The Difference In 30 Minutes...NO SEALER OR JB CAN FIX BIG LEAKS..Do Not Expect Miracles...
Old Feb 2, 2021 | 11:51 AM
maxxman04
Mar 1, 2017 9:54 PM
lonewolf04
Nova & Chevy II
Dec 19, 2011 11:01 PM
th3sh1zn1t
Oct 21, 2007 10:11 PM
