Tow Hitch Not Lining Up
Old Jan 21, 2017 | 7:36 PM
Mariano Gru's Avatar
Default Tow Hitch Not Lining Up
Have an 04 Suburban 1500 2WD.
I have a class 3 hitch supposedly for this model. When I install it, the the bolts on either side on the frame line up great, but the two center bolts on the bumper are off by about 1/2 inch. My trailer is 4500 lbs with a 500lb tongue weight. Can I tow without these two center bolts attached? Do those two bolts make a big difference if I take it easy driving?
Is there a way to line these up?
thanks
Old Jan 21, 2017 | 7:42 PM
intheburbs's Avatar
Seriously? You mean the two bolts directly above the receiver, where all of the stresses will be concentrated? With a 4500-lb trailer?
You're really going to use something that doesn't fit right, instead of paying $150-$200 for a part made specifically for your truck?
Old Jan 21, 2017 | 7:53 PM
OK, would you just use the bumper ball instead?
Old Jan 21, 2017 | 7:59 PM
kevinkpk's Avatar
Originally Posted by mariano gru
ok, would you just use the bumper ball instead?
nope!
Old Jan 21, 2017 | 8:07 PM
kevinkpk's Avatar
I can't believe you are pulling a 2 1/2 ton trailer with a 1/2 ton suburban or wanting to.
Old Jan 21, 2017 | 8:12 PM
So I got a different hitch they fit properly, wouldn't 4500lb be fine since I have a ~7200lb towing capacity?
anyone have experience with a similar setup?
Old Jan 21, 2017 | 8:46 PM
kevinkpk's Avatar
I don't know what the GVW towing wieght is on a 1500, probably ok. The hitch ball is rated at 2000 lbs max
Old Jan 21, 2017 | 9:22 PM
My bumper hitch is rated for 500tw and 5000lb tow capacity
Old Jan 21, 2017 | 10:15 PM
maybe your thinking of bumper pull not hitch pull.
Old Jan 21, 2017 | 10:36 PM
I'm going to try to loosen everything again and see if the bumper slides back enough.
