Trailer tow mode not working
Old May 24, 2011 | 10:24 AM
factorypilot's Avatar
Default Trailer tow mode not working
Tried to use the tow mode and light on dash didn't come on. Transmission is going into overdrive, so not the bulb.
Has anyone had a problem with this? I tried checking fuses but may not have tried the right one as they are labled a little difficult to understand.If fused anyone tell me which fuse I should go to?
I don't remember if I used it since I had the tranny filter changed, so I question if it is possible something was disturbed when the pan was off. Would like to eliminate possibilities before going to the shop.
It's an '05 1/2 ton Sub
Old Jun 9, 2011 | 7:46 PM
Finally got around to look at this problem. Took steering column cover off and found a wire from the switch in the shift lever to be broke. The second wire was near breaking also. I soldered a splice to both wires to give a little more length and for now is working.
Wires are in a orange casing if anyone has to pursue this issue.
Old Jun 10, 2011 | 7:17 AM
SabrToothSqrl's Avatar
Default yes
thank you for the info
Old Jun 10, 2011 | 12:35 PM
Thanks for the feedback.
Any indication as to why they broke?
Old Jun 10, 2011 | 6:31 PM
hicksvilleshick's Avatar
awesome, hopefully thats whats wrong with mine...
:chug:
Old Jun 10, 2011 | 10:49 PM
well I tore my dash apart tonight... found 1 wire running to the tow/haul switch (that I could tell) and it seemed to be fine. I've been fighting the cluster bouncing dead over bumps so I was checking the connections on it too... seems I'll have to look for and maybe re-run a new ground for it... 2001 Suburban. A week ago, the whole instrument cluster would - JustAnswer
I'm hoping it's whats also causing it to intermittantly shut down the motor too. :dunno:
but I found out tonight that if I put it in 1st and hit the tow/haul switch it mystically works. This pleases me. I'm just bummed I have to take the dash back apart tomorrow. ugh.
:chug:
Old Jun 11, 2011 | 8:44 AM
73shark, the wires that run up to the switch in the shift lever are held to the steering column with a retainer and it appears to have pinched the wires at that area. Maybe from the tilt steering over the years acted like a can and weakened the wires to the point of breaking. Since I couldn't get enough slack with what was left I spliced a little better than a inch or so of some wire I had laying around to get length I felt comfortable with. The wire was very small gauge, I hope it holds or a new shift lever will be needed. I suppose I could buy a switch and mount it somewhere on the dash but I don't think that will be very appealing to me.
Old Jun 11, 2011 | 3:27 PM
update: pulled dash back out. got some blue flappy wire splicers and ran a new ground for both the black/white wires (GND) from the plug and now my cluster doesn't seem to doink out, (yet) and my oil pressure gauge is less twitchy. the tow/haul button now works from 2nd gear instead of just 1st, (i'll be real happy when I can get it to work from drive) and my abs and brake light ain't come on yet.
down side, it keeps telling me I'm low on washer fluid, and I know it's not as I topped it off last night. ugh.
:chug:
Bill Van Steenwyk
Apr 27, 2014 8:27 AM
mn808gade
Sep 18, 2012 10:13 AM
mummp
Oct 13, 2009 8:48 PM
racerx55
May 17, 2007 8:05 AM
Clay24
Jan 4, 2007 1:37 AM
