Trans Temp
Trans Temp
What kind of trans temps are you guys seeing towing a 14 foot enclosed trailer. I just got an 08 'burb and just want to know what is a safe temp. Thanks for the help.
Welcome to the forum,
there will be lots of opinions on it but several factors will apply, do you have a aux trans cooler?
A search of the forum will yield some good info, I believe the general consensus is any extended periods of towing over 210f is probably not healthy for the tranny, but regularly servicing can help extend its life, and adding an ext cooler will help...
Trans temp
I do think it came with an aux trans cooler stock. I have been a Ford guy for all of my driving before this, and havent had this option before so I didnt know what to look for.
It will be in the front of the radiator... check out these links
https://chevroletforum.com/forum/tah...install-35484/
Chevrolet Forum - Chevy Enthusiasts Forums - Search Results
Question on adding a ext. tran cooler. How do you monitor the temps before/afterwards if you do not have a tran. temp gauge in your instrument cluster panel? My current truck has a tran cooler and gauge so I can watch the temps. The Suburbans I have been looking at picking up do not have this gauge but would probably like to add an ext. tran cooler since I tow a 5700lb 28' long camper.
skategranger
February 18th, 2013 2:38 PM
Mauler
March 2nd, 2009 6:40 PM
june82000
February 10th, 2008 7:47 PM
