Trans Temp
Old Mar 27, 2011 | 1:15 PM
mercracing's Avatar
Default Trans Temp
What kind of trans temps are you guys seeing towing a 14 foot enclosed trailer. I just got an 08 'burb and just want to know what is a safe temp. Thanks for the help.
Old Mar 27, 2011 | 2:41 PM
Welcome to the forum,
there will be lots of opinions on it but several factors will apply, do you have a aux trans cooler?
A search of the forum will yield some good info, I believe the general consensus is any extended periods of towing over 210f is probably not healthy for the tranny, but regularly servicing can help extend its life, and adding an ext cooler will help...
Old Mar 27, 2011 | 2:49 PM
mercracing's Avatar
Default Trans temp
I do think it came with an aux trans cooler stock. I have been a Ford guy for all of my driving before this, and havent had this option before so I didnt know what to look for.
Old Mar 27, 2011 | 2:52 PM
It will be in the front of the radiator... check out these links
https://chevroletforum.com/forum/tah...install-35484/
Chevrolet Forum - Chevy Enthusiasts Forums - Search Results
Old Mar 27, 2011 | 3:24 PM
rosencra38's Avatar
Question on adding a ext. tran cooler. How do you monitor the temps before/afterwards if you do not have a tran. temp gauge in your instrument cluster panel? My current truck has a tran cooler and gauge so I can watch the temps. The Suburbans I have been looking at picking up do not have this gauge but would probably like to add an ext. tran cooler since I tow a 5700lb 28' long camper.
Old Mar 27, 2011 | 3:51 PM
mercracing's Avatar
Shoot the pan with a temp gun. Or you should be able to install your own temp gauge and sender without too much trouble.
Old Mar 27, 2011 | 3:59 PM
mercracing's Avatar
Looked in the front by the radiatior, did some reading and yes I have the aux trans cooler
Old Mar 27, 2011 | 4:34 PM
Great, then you should be good to go
Old Mar 27, 2011 | 5:01 PM
You might try a few forum searches, as I believe this has been discussed but I don't recall what the outcome of adding the ext temp gauges has been.
Old Mar 28, 2011 | 12:15 AM
Do you have a DIC? If so, the tranny temp is one of the options.
skategranger
Feb 18, 2013 2:38 PM
montana suburban
May 11, 2010 5:19 PM
Mauler
Mar 2, 2009 6:40 PM
june82000
Feb 13, 2008 7:26 AM
june82000
Feb 10, 2008 7:47 PM
