window rolls down on start?
Old Jan 11, 2012 | 10:24 PM
taelir's Avatar
Default window rolls down on start?
Hi all, we recently purchased an '05 Suburban and are having problems with the rear driver's side window. We've discovered that the window will roll down within 20-30 seconds of either starting the vehicle or just turning the key to the 'ON' position.
My husband says he didn't have this issue until he turned on the automatic climate control today. I thought I would check here and see if anyone has dealt with something similar before he dives in blindly to try and find the problem.
Any suggestions/ideas would be greatly appreciated. Thanks!
Old Jan 11, 2012 | 11:57 PM
Welcome to the forum.
Could be that the door switch has failed in the "DOWN" position. Could check by pulling the switch and unplugging and see if the window still goes down as before. If it doesn't, then probably the switch is defective. If it does, then most likely a wiring short.
Old Jan 12, 2012 | 4:05 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> taelir,
73shark offers a great suggestion. If that doesn't work, you may want to take it in for a quick inspection.
Keep us posted!
Louis
GM Customer Service
Old Jan 12, 2012 | 5:11 PM
taelir's Avatar
Thanks! I will let the husband know and either he or I will go check the switch first. I'll be sure to report back!
Old Jan 13, 2012 | 10:44 PM
taelir's Avatar
Looks like it indeed was the switch! Now we're off to get a replacement.
Thanks so much for the quick replies!
Old Jan 14, 2012 | 12:18 AM
You're welcome.
Hope it was indeed the switch. Let us know either way. Thanks.
Old May 3, 2012 | 1:18 PM
taelir's Avatar
I know I'm dredging this up from the depths of oblivion, but it seems we haven't solved the problem yet. I guess we assumed the rear driver's side switch was the problem when we disconnected it and had no further issues.
We did end up purchasing a new switch for the rear driver's side window (we waited until it was warmer out, when we'd actually be using that window)....but the problem persists. At first, we popped in the new switch and nothing happened. No roll-down on start, no roll-down at ALL. Took the switch out, put the original one back in, and nothing again. We figured the problem was elsewhere, so we reconnected the new switch and left everything alone.
A couple days later, one of my kids discovered that the window would roll up/down using that switch only. I couldn't control it at all from the driver's door panel. Then a day or so after that, the window began rolling down on vehicle start again. We disconnected the switch and are back at square one.
Where's the electrical gremlin hiding? Is it the driver's window switch panel? I lean towards not, but right now I just don't have a lot of ideas.
Thoughts?
native1223
K5 Blazer
Mar 10, 2015 6:46 PM
Shearwig
Nov 16, 2006 11:18 PM
