2005 Suburban 4wd actuator
Old Feb 1, 2023 | 3:00 PM
rbinkerd's Avatar
Question 2005 Suburban 4wd actuator
I'm having issues with my 4wd. Getting the Service 4WD message. I have tested my switch and it is good. I can hear the encoder motor working. Took out the actuator and it was bad. Put in a new one and still getting the same message. I removed the actuator and bench tested it and it goes in and out as it should. When I took it out it was at least partially extended. As soon as I put the power and negative on the correct pins, it retracted. Putting negative on the trigger pin makes it extend, removing it and it retracts all like it should. I do have 12V on negative on the correct connecter pins.
I used a small dowel rod to push the piece inside that slides the fork but can I only push about 1/8 inch or so. How much pressure does it take?
I don't have a lift, so I could not rotate either front wheel, to see if it might be that the gear inside needs to be moved to line up.
Any help is appreciated.
Thanks
Rory
wbywmu
1988 - 1998 (GMT400)
Apr 20, 2022 1:02 PM
azdave35
Nov 20, 2021 10:55 PM
bob2010
Feb 1, 2010 6:42 PM
Dennis B
Feb 24, 2009 10:05 PM
redbear2008
Feb 22, 2007 3:47 AM
