2007 Possesed Lift Gate Problem
Old Jan 15, 2012 | 8:42 PM
wile13's Avatar
Default 2007 Possesed Lift Gate Problem
Well my wife did it again...when activating the rear auto lift gate with the key fob it will not open. However the inside switch will open it. Any ideas?...
Thanks,
Eric
Old Jan 15, 2012 | 9:38 PM
Welcome to the forum.
Does the rear handle latch work? Do the rest of the key fob functions work? After it's open, will the fob close it?
May have to go thru the for programming procedure in the Owner's Manual.
Old Jan 15, 2012 | 11:41 PM
wile13's Avatar
Hi,
It never opens with the FOB the lights flash but that is usually it. The rear handle will make it flash the rear lights and you hear some unlock noise but never even opens.
So i don't believe it is totally broken if it works from inside.
Any other ideas?
Thanks,
Eric
Old Jan 16, 2012 | 1:08 PM
Does the close button in the bottom of the hatch work?
Old Jan 16, 2012 | 5:18 PM
Official GM Rep
wile13,
It sounds like the lock actuator isn't engaging completely. This is just a suggestion, not a diagnosis. You may want to take the vehicle in for an inspection. A certified technician will be able to offer an accurate diagnosis with a physical inspection.
Keep us posted.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Old Jan 18, 2012 | 12:48 PM
wile13's Avatar
Default Hmmm...
I appreciate the GM feedback, but don't understand if it opens from the front with NO ISSUE, why would it not open from the rear?
It uses the same system correct? Just a different button. Could the FOB be weak or an issue?
Thanks,
Eric
Old Jan 18, 2012 | 4:14 PM
Official GM Rep
wile13,
I suppose a weak FOB could be an issue, however then it would also be an issue with the locks, remote start, etc.
Have you changed the vehicles battery recently? Is the battery currently low? Is the liftgate button on the overhead console set to manual mode? Is the liftgate closed completely? The liftgate must be completely closed to power open or completely open to power close.
These are just additional suggestions, not a diagnosis. I encourage you to take the vehicle in for inspection.
Louis
GM Customer Service
Old Jan 19, 2012 | 12:39 PM
ousig2408's Avatar
is the truck locked when trying to open it with the remote??? if so it will do exactly what you described.
Old Feb 9, 2012 | 1:14 AM
Damien0869
Guest
Posts: n/a
Make sure the inside vehicle switch is not in the "LOCK-Out" position, when trying to utilize the Key fob. If lock-out is not on and it still does not work, head into the dealer and have them reset the system with the Tech II scanner and have it all calibrated correctly.
Good luck!
steve8691
Aug 3, 2023 5:23 AM
dolljason.p
Jul 25, 2020 8:36 PM
RJK
Aug 2, 2019 5:50 PM
firelance911
Aug 26, 2010 2:31 AM
rebel8ball
Oct 29, 2009 3:23 AM
