#4 Cylinder Misfire
Old Nov 14, 2011 | 2:08 PM
dogman1313's Avatar
Default #4 Cylinder Misfire
I have a misfire on the #4 cylinder, I have changed the Spark Plugs, The Plug Wires, The Rotor & Distributor Cap. But I still seem to have the miss. If it is the #4 injector, how do I replace it. I swapped plug wires, & changed the Spark plug, what else could it be ? I forgot to mention it is a 1999 Suburban 4x4
thanks in Advance
Old Nov 14, 2011 | 2:41 PM
kevinkpk's Avatar
Is it have a check engine light? If so, can you read the code?
Old Nov 14, 2011 | 2:49 PM
dogman1313's Avatar
Yes it has a code & you can feel the misfire , the code is po304 which I believe is a #4 cylinder misfire.
Old Nov 14, 2011 | 2:56 PM
kevinkpk's Avatar
PO0300 is misfire, so 304 indicates to me #4. What did the plug(s) look like?
NGK Spark Plugs USA
Old Nov 14, 2011 | 3:13 PM
dogman1313's Avatar
The # 4 was kinda white, w/ a little black, it wasn't wet, I just took an old wire & replace the new one, I changed the new plug out with another new one but still have the misfire. I have an AutoEnginiuty program that I use, plus a generic scanner & they say the same, but what could be causining the misfire on #4?
Old Nov 14, 2011 | 3:20 PM
kevinkpk's Avatar
White deposit, with black. I'd say injector.
Old Nov 14, 2011 | 3:25 PM
dogman1313's Avatar
how do you replace the injector ?
Old Nov 14, 2011 | 3:42 PM
kevinkpk's Avatar
Gotta remove the intake, that also means more than just injectors, but also gaskets. I looked on you tube for something to help, but nothing. I'd also add, replace all 8. You "may" have 1 bad, but going to this level, not replacing all of them just a matter of time befoer you'll be back into it.
Old Oct 24, 2012 | 12:48 PM
armystrong928's Avatar
Cold also be o2 sensors mine is doing it too. But my plugs are a rust color.
Old Sep 22, 2014 | 10:22 AM
Bruin4LB's Avatar
thanks in Advance
So my P0304 message for piston 4 misfire with Traction Control & Service Stabilitrak message led to Collapsed Lifters on the right hand side. This only uncovered after I replaced spark plugs, spark plug wire, swapped ignitors, performed fuel injection cleaning. Condition worsened while I was on vacation. I started receiving a P1175 message, constant engine clicking noise, in addition to consuming 2 qts of oil. In the end, took it to dealer after local mechanics wanted to replace the entire engine. Replaced Collapsed Lifters on the both sides and was good as new.
Trupster
Jul 8, 2007 6:26 PM
99Silverado
Jun 8, 2007 5:59 PM
adambraap
Feb 16, 2007 7:49 PM
adambraap
Jan 28, 2007 9:58 PM
akimber
14
Aug 22, 2006 11:45 AM
