Brake Kit Advice Needed
Old Feb 6, 2017 | 5:55 AM
saabman's Avatar
Question Brake Kit Advice Needed
Hi there
My 2000 Chevy Suburban 1500's brakes are on their way out and I am looking at various direct fit brake kits.
I have found reasonably priced Power Stop kits Z23 or Z36 but I am unsure of their quality...
It would seem that only the Z36 offer an upgrade on the rear with twin pots but front stays standard twin pots too...
Any advice would be welcome specially as I am ordering overseas and don't really won't to get it wrong :-D
Thanks ;-)
Old Feb 6, 2017 | 8:01 AM
twin pots....do you mean dual piston calipers?
Are you towing heavy trailers?
Old Feb 6, 2017 | 8:08 AM
saabman's Avatar
Yes sorry dual piston :-)
Tow up-to about 6000 pounds max I guess (Hope that's converted correctly should be about 3000 kg)
Old Feb 6, 2017 | 7:08 PM
From everything I've read, you'll want to avoid Chinese rotors.
Old Feb 6, 2017 | 7:55 PM
if your driving up/down mountains and heating up your brakes, go semi metallic pads. they give a different pedal feel and may be noisier but they won't fade; everything is a trade off. Make sure the trailer brakes are in good order. The rear caliper change is not something i would bother with but to each their own.
Old Feb 7, 2017 | 3:41 AM
saabman's Avatar
OK so you would go for standard setup with just the upgraded semi-metallic pads? No need for extra pistons either front or rear?
Old Feb 7, 2017 | 8:27 AM
all the extra pistons do is make it easier/faster to apply mechanical force to the pads.
the fronts are already dual piston. dual in the rear are used in heavy duty 3/4 ton trucks that tow 10000lbs.
Old Feb 7, 2017 | 9:05 AM
saabman's Avatar
Ok thanks for that, I will then be more in favor of refurbishing my OEM brakes then
Thanks for the advice!
Old Feb 7, 2017 | 2:02 PM
Be sure to go thru the proper new brake break-in procedure.
Old Feb 7, 2017 | 6:48 PM
don't ignore the trailer brakes
