rear semi-floating axle bearings
Old Mar 24, 2010 | 2:15 PM
VanGo's Avatar
Default rear semi-floating axle bearings
If you need to replace your axle bearings and seals, O'Reilly Auto Parts will loan a slidehammer and bearing removal attachment. You get your money back when you return the equipment.
I have a bad seal on the LR wheel and it is slinging 75-90w oil all over the brake shoes. I think my bearing may have run a little dry, it makes a noise. At 170K miles, I'm replacing both sides
Old Jan 21, 2011 | 8:40 AM
rbrace's Avatar
thanks for the advice no oreily,s
here in vt auto zone does the same
ChevyJo
Nov 19, 2014 11:56 AM
bwaddell
10
Oct 20, 2007 11:37 AM
