Tracker 1989-2004
Platform: CAMI (Suzuki)
1998 Tracker Voltage Drop
Old May 4, 2021 | 8:29 PM
  #11
L84sky's Avatar
Just a quick follow-up on why testing under load is sometimes required.
Here the 6 Ω resistance is the headlight filament.
The battery cables are good and the headlight switch is open.
The voltmeter will read 12 volts.
The additional 6 Ω resistance is a faulty connector on the battery cable.
The voltmeter will still read 12 volts with the headlight switch open.
The good and bad circuits look identical to a voltmeter.
With the headlights ON in the good circuit the voltmeter will still read 12 volts.
But in the bad circuit the voltmeter now reads 6 volts.
That bad connection doesn't reveal itself until you try to force current through it.
An ammeter in series with the load would show 2 amps in the good circuit.
Conversly, the ammeter would only read one amp in the bad circuit.
John_davis1984
1988 - 1998 (GMT400)
Jun 4, 2020 11:51 AM
BigBlockNBK
Sep 21, 2017 9:58 PM
DugEDugg
Jan 22, 2016 2:17 PM
ckbrownla
Nov 27, 2013 7:58 AM
I_am_10_ninjas
Apr 19, 2012 6:33 PM
