2000 chevy tracker wont run right.
my tracker runs fine for 2 mins but when it warma up
and you put it in drive it wont move and it wants to stall
I have the pedal all the way down and the rpms wont go
up. then I put it in nutreual and rmps work fine then I
put it back in drive or reverse it jumps then rmps go down
instantly and wont move and wants to die. can some one
help me??? I replaced my throttel body and it still dos
same thing. but it runs normal for 2 mins then dosnt
want to move.
want to move.
did the throttle body come with new sensors like the throttle position sensor and an idle air control valve? if not I would suspect those items.... in that order...it would also be a good idea to check the fuel pressure... the pressure and volume may be too low only enough to idle the engine but not enough to run it under load...
