Tracker 1989-2004
Platform: CAMI (Suzuki)
2000 chevy tracker wont run right.
Old Jul 4, 2012 | 9:20 PM
bretb2012's Avatar
Default 2000 chevy tracker wont run right.
my tracker runs fine for 2 mins but when it warma up
and you put it in drive it wont move and it wants to stall
I have the pedal all the way down and the rpms wont go
up. then I put it in nutreual and rmps work fine then I
put it back in drive or reverse it jumps then rmps go down
instantly and wont move and wants to die. can some one
help me??? I replaced my throttel body and it still dos
same thing. but it runs normal for 2 mins then dosnt
want to move.
Old Jul 5, 2012 | 2:56 PM
Camaro 69's Avatar
Site Ambassador
Is your check engine light on? If so, do you have a code scanner or know someone who does?
Old Jul 5, 2012 | 6:23 PM
Andy Talenda's Avatar
If you or a friend doesn't have a code reader, you can stop by your local auto parts store. They can usually scan it for you, and let you know the code.
Old Jul 5, 2012 | 7:00 PM
Camaro 69's Avatar
Site Ambassador
^ I thought that too, but then figured he probably didn't want to push the car to the store since it doesn't move under it's own power!
Old Jul 5, 2012 | 9:20 PM
did the throttle body come with new sensors like the throttle position sensor and an idle air control valve? if not I would suspect those items.... in that order...it would also be a good idea to check the fuel pressure... the pressure and volume may be too low only enough to idle the engine but not enough to run it under load...
2004 Red
Aug 16, 2015 10:02 PM
fmxrider7
Apr 29, 2014 2:42 PM
j_w_hicks
Apr 25, 2010 8:40 AM
76LUVStepside
Sep 7, 2007 4:29 AM
