Tracker 1989-2004
Platform: CAMI (Suzuki)
Old Jul 29, 2015, 7:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
2000 tracker power steering fluid change
Old Nov 22, 2011 | 3:21 PM
CACTUS24's Avatar
Default 2000 tracker power steering fluid change
Want to drain the power steering fluid and refill with dexron vi.
Looks like there is a drain plug on the power steering unit,
driver side, front, below the return outlet where the rubber hose is connected.
Anyone use this drain plug, i am not interested in removing any hoses.
Old Nov 22, 2011 | 3:34 PM
Mike Sigmond's Avatar
ROTM Coordinator
I dont know much about that model but draining the pump only changes the fluid in the pump, the hoses & rack & pinion will still have the old fluid in them. There may be a drain on the rack & pinion, im not sure.
Just my 2 cents
Old Nov 23, 2011 | 5:34 PM
CACTUS24's Avatar
It will drain the return line and reservoir tank, just do it every year.
Old Jul 29, 2012 | 6:51 AM
CACTUS24's Avatar
Quess i will remove the return hose from the pwr steer unit return
outlet, it is on the left end, the hose then connects to the return tube that runs under the radiator and then up to the reservoir.
Old Jan 9, 2013 | 2:39 PM
Domino3665's Avatar
Default Power Steering Fluid update
What if you just cycled the power steering fluid like you do for a radiator flush? Only drain the reservoir. Then replace the reservoir fluid. A partial replacement would provide newer fluid without worrying about leaks or getting air in the system lines.
Old Jan 12, 2013 | 9:15 AM
CACTUS24's Avatar
Default Power Steering Resevoir
The Resevoir has a plastic screen at the fluid level, so you cannot
remove the fluid with a sucksion hose, also do not want to remove the return hose at the bottom of the resevoir. i will get back to it in April, keep the tracker covered up in the garage, still cold in Pennsylvania.
Old Jun 27, 2025 | 7:06 PM
-Nate's Avatar
Question Power steering fluid change / flush
? Did you ever get this done ? .
I want to do it on my 2000 2L Tracker, not really wanting to remove the hose and have it drain every where in my nice clean and dry engine compartment .
Comments / suggestions ? .
TIA,
Old Jun 29, 2025 | 9:20 AM
-Nate's Avatar
Post Odd Notifications ?
I hope to do this soon, I was looking at the clearance and hope I can squeeze an old style ATF funnel below the reservoir and remove the lower hose, I'm sure it'll make a mess and I try hard to keep my engines clean and dry but this needs doing periodically .
Why do I keep getting notifications when there's no new reply ? .
Old Jun 30, 2025 | 1:46 PM
-Nate's Avatar
? Why am I getting new post notifications when the newest post was in 2013 ? .
wep54
Nov 11, 2013 8:49 AM
DeHartShadow
Mar 28, 2010 10:10 PM
junklady
Oct 28, 2009 6:01 PM
rick2609
Nov 2, 2007 11:08 AM
damaarh
Sep 6, 2006 2:13 PM
