Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 chevy tracker transmission cooler pipe
Old Aug 25, 2023 | 6:58 PM
Trackertravie's Avatar
Default 2002 chevy tracker transmission cooler pipe
Hey guys running into a problem when I got the car the guy before put a piece of rubber hose over the transmission cooler pipe (the metal pipe that connects to the transmission via banjo bolts) to try and stop a leaked, well shocker it didn't work. I can't find the part to save my life, I was wondering if anyone has a soruce where to get these or know what thread size the banjo bolt is so i can buy a universal banjo and make my own lines
Old Aug 25, 2023 | 8:36 PM
L84sky's Avatar
These are Suzuki part numbers for my 2001 Tracker automatic transmission.
Old Aug 26, 2023 | 2:44 PM
Ok that helps out a lot, what website did you order them off?
Old Aug 26, 2023 | 3:11 PM
L84sky's Avatar
I have bad news and more bad news.
Partsouq only wants $43 for the pipe but they don't have any.
MegaZip says they have both pipes but they want over $100 each. If it helps I saw plenty of used ones on ebay.
Old Aug 26, 2023 | 8:34 PM
I saw on Partsouq they didn't have any, that's crazy over a 100 bucks for one line and I need 2 , i did some more digging and found out what size and thread the bolt is so i ordered 2 banjo bolts with beveled end and gone run my own hose...hopefully and will work out
Old Aug 26, 2023 | 8:43 PM
L84sky's Avatar
Parts description says the banjo bolts are 14 mm diameter and 27 mm in length. I don't know the thread pitch offhand.
I would love see pictures of your repair after you're done.
Old Aug 26, 2023 | 8:50 PM
Yeah for sure! I should have the part tomorrow and if all goes to plan I'll be putting them in tomorrow, I love older vehicles and will do what ever it takes to keep them going haha
Old Dec 4, 2024 | 6:29 PM
Dutchman 1234's Avatar
Default Banjo bolt specs for a 2001 Chevy tracker
Hi I was wondering if the banjo bolts you got worked for the tracker tranny... Have same issue as you and having trouble finding specs on the size needed
Al Bundy
Mar 21, 2022 8:20 PM
almsthvn27
Oct 8, 2019 7:30 PM
Ron6519
51
Dec 12, 2018 10:14 PM
TomS209
Jul 10, 2010 6:33 PM
sudo
Jul 20, 2007 10:51 PM
