Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 zr2 electrical trouble
Old Nov 3, 2011 | 8:48 PM
puck13's Avatar
Default 2002 zr2 electrical trouble
Wife has tracker in Colorado. I am in Pa. She has electrical trouble during trip. 15 amp fuse to DRL, heater blower and Rear defroster blew. Changed fuse. blew again. The problem is no heater fan. She will be home soon (Pa). Any known problems with this circuit? I suspect a shorted relay.
Thanks in advance.
Craig
Old Nov 11, 2011 | 10:49 AM
puck13's Avatar
Default Tracker electrical problem solved
Wife returned home. Found problem. Relays under hood near under hood fuse panel wires run close to strut tower. Yellow with green trace wire chaffed on strut tower, shorting circuit. Found help in edmunds web site. Similar problem.
Thanks for all the lookers!
Craig
Old Oct 31, 2012 | 10:39 AM
H969's Avatar
Thanks for telling what happened!! The same happened to me, easy fix if you find what it is!!
Knat
Feb 7, 2014 7:57 AM
Used2ZR2
Nov 26, 2009 11:58 AM
49er-ratrod
Jul 19, 2009 11:41 PM
bobbie95poca
Feb 12, 2008 1:48 PM
mthomp
Dec 18, 2005 11:57 PM
