Tracker 1989-2004
Platform: CAMI (Suzuki)
2002 zr2 electrical trouble
Old November 3rd, 2011, 8:48 PM
puck13's Avatar
Default 2002 zr2 electrical trouble
Wife has tracker in Colorado. I am in Pa. She has electrical trouble during trip. 15 amp fuse to DRL, heater blower and Rear defroster blew. Changed fuse. blew again. The problem is no heater fan. She will be home soon (Pa). Any known problems with this circuit? I suspect a shorted relay.
Thanks in advance.
Craig
Old November 11th, 2011, 10:49 AM
puck13's Avatar
Default Tracker electrical problem solved
Wife returned home. Found problem. Relays under hood near under hood fuse panel wires run close to strut tower. Yellow with green trace wire chaffed on strut tower, shorting circuit. Found help in edmunds web site. Similar problem.
Thanks for all the lookers!
Craig
Rager (April 6th, 2023)
Old October 31st, 2012, 10:39 AM
H969's Avatar
Thanks for telling what happened!! The same happened to me, easy fix if you find what it is!!
Knat
February 7th, 2014 7:57 AM
Used2ZR2
November 26th, 2009 11:58 AM
49er-ratrod
July 19th, 2009 11:41 PM
bobbie95poca
February 12th, 2008 1:48 PM
mthomp
December 18th, 2005 11:57 PM
Quick Reply: 2002 zr2 electrical trouble
