Tracker 1989-2004
Platform: CAMI (Suzuki)
No start
Old June 23rd, 2024, 4:24 PM
  #61
MoterMitch's Avatar
put almost 500 miles on it since you helped me get it running, thanks again! I'm currently trying to pass emission inspection, code PO 450.EVAPORTIVE SYSTEM PROBLEM. I know that's one of the wires that I delt with at the computer and I'm doing my homework on the system and the diagnostic's. I will keep you updated!Hey sky if you see this i ordered and got a new scanner AUTEL-MAXIICOM MK808S-TS. online and it didn't work from the box and I'm trying to get situation resolved
Old June 23rd, 2024, 5:05 PM
  #62
L84sky's Avatar
P0450 is a bad voltage on the FTP signal wire.
Put a voltmeter on C1-27. If it reads near 5 volts you probably have an open wire. A normal reading with the gas cap removed would be around 2.5 volts. Pray it's an open wire because that 3-pin FTP sensor is not available anywhere.
I am considering that same scanner. Let me know what you think about it.
Old June 23rd, 2024, 5:10 PM
  #63
MoterMitch's Avatar
your the best thank you I will definitely keep you posted!!!
Old June 28th, 2024, 6:42 AM
  #64
MoterMitch's Avatar
sky did I tell you I'm old and blind? i repined two wires # no 27 and 28 were one box to the left. I moved them and light problem solved.!!! but I'm now having o2 sensor codes, I think my depinning process may have compromised their connections on some of the pins. I sent the scanner back for a full exchange looking forward to that i hope i can sort this all out but i won't quit now thanks again SKY!!!
Old June 28th, 2024, 8:05 AM
  #65
L84sky's Avatar
I'm old too but I'll keeping working on my Tracker until I can't contort my body into tight spaces.
Old Yesterday, 9:32 PM
  #66
MoterMitch's Avatar
hey, ski my tracker still runs! with a few glitches so I decided to strike a deal with a guy here in Houston that has several trackers in his junk yard. I purchased a complete wiring harness from him everything from the seats forward to the headlights. That took me a while to extract! and it was a more optioned truck i even got the computer. i bought the whole thing for 100.00 dollars and he has more parts available. I have his contact info! my question is do you have a detailed set of instructions for the removal of the main wiring harness along the fire wall? it took me forever to get it out! Ilike the autel scanner and I'm learning how to use it.
Old Today, 6:10 AM
  #67
L84sky's Avatar
I do not.
This is the best picture of the firewall routing I have.
Old Today, 7:54 AM
  #68
MoterMitch's Avatar
Thanks Sky what I was looking for is the main harness inside the truck along the firewall,dash removal??? I managed to remove the donor harness but there were some places where I was rough with the dash and I didn’t want to do that with my vehicle!
Old Today, 8:25 AM
  #69
L84sky's Avatar
That looks like way more than just the Main harness.
Suzuki breaks the wiring down into 12 distinct harnesses. The Main harness is just one of the 12. All of the Main harness connectors start with a designation of "E" as in E61 going to the PCM (connector C1 in Chevy speak). I have never removed the dash from my Tracker so I can't be much help there.
03ZR2V6
April 23rd, 2018 8:04 AM
RoosterP
November 6th, 2014 8:39 AM
sum67
December 2nd, 2010 7:13 PM
TJKashin
September 26th, 2007 2:15 PM
boydbl
July 10th, 2007 4:59 PM
Quick Reply: No start
