TrailBlazer 2002-2009
AC not...
Old Aug 4, 2013 | 12:23 PM
SASScowgirl's Avatar
Question AC not...
My a/c will not blow out the front registers...it only blows out the defrost vent...I replaced the a/c/ heater control with no change...could there be a servo giving me that problem. Any help please...thanks.
Old Aug 4, 2013 | 9:46 PM
most chevy products now use electronic actuators to move the temp, mode and recirc blend doors. you may have a faulty actuator if the mode door does not move out of the defrost position.
if you can find the actuator (I'm not sure where it is for a trailblazer), see if its rotating when the mode control **** is adjusted.
A body code may be set in the HVAC or BCM but you would need a full function scan tool to retrieve it. With a scan tool you could also verify movement of the mode door by watching the "door position counts" change as the door moves.
attycda
Dec 27, 2021 12:34 PM
Xerklite
Apr 27, 2013 9:14 AM
krustyjonez
May 17, 2011 8:02 PM
ezzyboy954
Feb 9, 2011 12:12 PM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
