TrailBlazer 2002-2009
Can I add remote door locks
Old Jun 28, 2014 | 9:12 PM
trollingforwalleye's Avatar
Default Can I add remote door locks
I have a 2007 TB and had it at the dealer. They looked up the vin and the truck has electric door locks but not remote ready. What needs to be done to setup a remote lock opener?
Old Aug 8, 2014 | 5:20 PM
vipergg22's Avatar
Default locks
I think you have to replace the liftgate module in the back hatch with one that supports it and possibly have it programmed at the dealer and of course get the correct gm fobs. i'm in the same boat ,no RKE .
Old Aug 11, 2014 | 5:37 PM
Default Grrr
When I bring it in for the 3rd recall GRRRRR I'll ask for prices
Old Aug 16, 2014 | 5:16 PM
jonhamnwa's Avatar
Default I have an 07
I ordered the key fob from amazon fairly cheap came with instructions I did what the page said and I have a fully working remote door lock and unlock
the key is it seems to reprogram the computer while holding down 2 buttons
on the fob then the door locks locked and unlocked and now it is all good
Old Aug 16, 2014 | 5:22 PM
jonhamnwa's Avatar
Default key fob
Robot Check
it is $18 and it worked on my 2007
Old Aug 16, 2014 | 5:27 PM
jonhamnwa's Avatar
Default not remote ready
is we only can do it I proved them wrong they told me the same thing
if you click the robot check in above reply it will take you to the amazon page
Old Aug 17, 2014 | 1:56 PM
Default 07 remote
Just ordered 1. wish me luck
Old Aug 17, 2014 | 7:53 PM
vipergg22's Avatar
Default remote
Look in your glovebox for the printed codes, if in those codes somewhere it says AU0 then you have a remote lock ready and you just need fobs to program , if AU0 is not present like mine you cannot program fobs and would have to replace the LGCM . Also if you have a doorlock on the passenger side of the vehicle for a key it will likely not have RKE.
Old Aug 18, 2014 | 4:31 AM
Default ??
When I hold down the unlock button and turn the ignition on and off twice it goes in program mode so I'm thinking it will work. where in the glove box is this code I am to look for?
Old Aug 18, 2014 | 9:24 PM
vipergg22's Avatar
Open the glovebox door and the placard is right on the door itself ,may need aflashlight to look at the codes on it. Look for AU0 somewhere in those codes.Even on mine it sounds like it is going into program mode but it never does because mine doesn't have RKE.
