TrailBlazer 2002-2009
passing wire through firewall 2003 TB
Old Oct 13, 2022 | 3:33 PM
brucemccampbell's Avatar
Default passing wire through firewall 2003 TB
I am trying to get a power cable through the firewall from under the dash behind the brake and I can't find any reference on the web on how to do this. Inside there is a great big rubber gromet but I can't see how to get the wire through. Has anyone ever done this?
Old Oct 14, 2022 | 5:42 PM
oilcanhenry's Avatar
Why do you want to run a wire into the engine compartment?
Old Oct 14, 2022 | 9:48 PM
I am installing the brake buddy 3 controller for my TB which I am going to flat tow behind my RV. I need to pass a thick (3/8” 4 wire cable) from the front driver side into the engine to connect to system to the power supply at the battery. It looks like the manufacturer has made a big hole for the brake system but there is nothing there for a clutch. I guess the trailblazer wasn’t offered with a manual transmission. The only thing that I can see is the latch release cable might have room but I can’t see the interior side where it passes through the firewall without taking down the trim that covers the inside. Job for tomorrow.
Old Oct 15, 2022 | 7:30 AM
Wherever you put the wire, make sure you seal it well with silicone seal to keep water out.
banner1124
Aug 27, 2019 5:11 AM
pappacherry49441
Jan 5, 2014 10:21 AM
danb113
Jul 15, 2010 5:07 PM
jpayne18
May 3, 2010 8:59 PM
oilman82
Dec 6, 2009 11:27 PM
