TrailBlazer 2002-2009
Trailblazer Engine SwapI have a 2004 Trailblazer and I need to replace the motor Help
Old Jul 8, 2014 | 1:28 PM
Pyro62's Avatar
Default Trailblazer Engine SwapI have a 2004 Trailblazer and I need to replace the motor Help
I have a 2004 Trailblazer and I need to replace the motor. I bought a second hand motor for it but the new motor has a sensor at the bottom of the base pan that my old engine does not have. Does anybody know what this is for? Or more importantly does anybody know what I need to do in order to add/bypass this sensor to my vehicle? Unfortunately, I do not know what year vehicle the new engine came out of. Any help would be much appreciated.
Pyro62's Avatar
By the way it's the 4.2L engine
Old Aug 16, 2014 | 12:16 AM
jonhamnwa's Avatar
Default you can try
I would try hooking up every thing you have and see if it runs without computer errors.
When I bought my 2007 there were no gauges working. There was a crappy super tuner installed in it I took it out and found wires cut everywhere. I tried to find a harness from a wrecked trail blazer, could not find a complete one. So I got the dash wiring from a Chevy front wheel drive mini van and then I bought all the heat shrink and solder that a local radio shack had in stock. I went to work cut soldier splice until I got every connector wired I replaced the radio from a GMC envoy no extra wires that went nowhere finally everything works. Except the stereo LOCKED....
Old Aug 16, 2014 | 12:01 PM
jonhamnwa's Avatar
Default you may have an 06 or 07 engine
my engine has a sensor on the bottom I do not know what it does but my trail blazer is a 2007 the wires disappear into a harness going up to the top area of the engine
Old Aug 16, 2014 | 12:05 PM
jonhamnwa's Avatar
Default if
if the engine has it but your truck does not if that is the only difference try changing the part that does not have the sensor from your old engine
MilChrisM
Oct 13, 2014 9:47 PM
novabill
Aug 14, 2013 3:20 PM
rmorton
Feb 9, 2010 12:48 PM
