Uplander 2005-2009
Platform: U-Body
08 uplander water leaking into floor
Old Sep 6, 2011 | 7:11 PM
rickmack21's Avatar
Exclamation 08 uplander water leaking into floor
I have a 2008 uplander it is leaking water into the floor, the water is clean no anti freeze or anything. found the condenser drain its not plugged up. I am trying to figure out how to remove the center console so I can try to see if it is pulled away from the firewall any sugestions thinking of getting rid of it! help before my husband trades it in!
Old Sep 7, 2011 | 8:28 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> If the vehicle is still in warranty I would take it to the dealership. They will be able to best help you figure out if you even need to remove the center console, or where the water is coming from. Keep us updated, and let us know how this goes if you take it to the dealership.
Breanne
Chevrolet Customer Service
Old Sep 7, 2011 | 9:08 AM
T.Neff's Avatar
Banned
Question
Breanne
Can you tell us if or how this would be covered??. Is it based on mileage or date of purchase??. Is there a service bulletin for this problem on this model??.Are you a ASE service writer??.
Old Sep 7, 2011 | 9:24 AM
kevinkpk's Avatar
Do you have water with the a/c on only? Are there any certain conditions that this problem occurs or all the time?
Old Nov 8, 2011 | 1:05 PM
riotz's Avatar
The problem is that the AC drain doesn't protrude far enough out of the firewall - in my van the entire bottom of the centre console is pretty much rusted out because of this, the salt on the floor and all the water leaking back in.. When the AC is running, and especially if you're parked facing uphill at a stop, the water drips out of the tube, and runs back along the outside of the tube back through the rubber grommet in the firewall, and back into the cabin floor... I'm pretty sure there's a thread on this forum about repairing this, sealing the grommet better etc. but my quick and easy fix was to cut a 3" piece of rubber hose (I forget what the diameter is, I used a piece of old power steering hose I had kicking around, so just take a measurement and buy a little piece) and sticking it over the drain tube in the firewall. if the piece of hose has a slight curve to it, and points down - all the better.
Old May 22, 2020 | 12:18 AM
manjotsc's Avatar
Do you have a picture of the drain hose in uplander, I am having trouble locating it. I had my foorboard rebuild, don't wanna spent money again.
Thanks,
Old Jul 24, 2020 | 10:29 AM
12three's Avatar
almost every uplander floor is gone in junkyards here...
Old Aug 13, 2021 | 12:52 PM
jharl's Avatar
Default AC condensate drain 08 Uplander
Took a piece of 5/8 cooling hose and a hose clamp about 2 in 3 inches long and clamped it to the end of the condensate drain tit. Condensate drain drains perfectly make sure the clamp is very tight. I hope this helps somebody
Old Aug 13, 2021 | 2:20 PM
manjotsc's Avatar
Default Drain Photo
Can you help with picture if possible? I could not locate it.
EFS463
Avalanche
Dec 1, 2014 11:56 AM
mixedbreed
Aug 24, 2011 9:51 AM
Monty5
Jul 3, 2011 8:44 PM
rtmtrrdr
May 22, 2009 7:06 AM
maxxmusle
Sep 6, 2008 5:50 PM
