Uplander 2005-2009
Platform: U-Body
2007 Chevy Uplander Low oil pressure
Old Jun 27, 2014 | 8:10 PM
toskala112's Avatar
Default 2007 Chevy Uplander Low oil pressure
Posted earlier about problem.....low oil pressure warning appeared on dash today...oil was just changed 500-1000k ago anyone experience the same problem? And what was the cause? Or does anyone have an idea what the problem could be only 146,000 k on vehicle it has always had regular oil changes....just another issue on top of many I have already have had with this vehicle LEMON!!!!!
Old Jun 28, 2014 | 6:23 AM
Papa Bear's Avatar
I have a 2007 uplander and it has been quite trouble free.
Please tell us what you have had problems with on your van.
Old Jun 28, 2014 | 5:56 PM
toskala112's Avatar
I had too have both front hub assemblies replaced, my rad blew last November followed by the ac compressor and cross over gaskets both going at the same time.....i have had to replace both rotors and pads aall around but thats just regular maintenance in my eyes....I have a hole bigger than my thumb rusted out just above the passenger side windshield....I figured buying newer would get away from old used car problems but I have had to replace more on this Uplander than any other older used vehicle I have had before....I still like it just disappointed in all the $ I have had to put into this vehicle especially with it only being 7 years old and less than 150,000k....
Old Jun 28, 2014 | 6:56 PM
toskala112's Avatar
The low oil pressure message appeared on my dash again twice today but then goes out.If there was a problem would it not stay on instead of going off after a few seconds? I know its probably not good to drive it but being a single vehicle family and having three children busy children its hard to just park it I rally dont want anything else to happen to it cause I need this vehicle to give some more years of use cause I have invested so much into it.Just not having any luck with this vehicle and really dont know what to do. I'm having the hole above the windshield repaired next week but have to drive it to Trenton to get it done and hopefully the service technicians there can figure out the problem once the body work is done.....
Old Jun 28, 2014 | 7:38 PM
Papa Bear's Avatar
Does the message appear while driving or while idling?
How long have you owned this van and how many miles on it when you bought it?
Where did the van come from? ... Peterborough area or somewhere up North?
Both front hubs were bad? That seems strange... I had my crossover gasket replaced under warranty, there is a TSB (technical service bulletin) on that fault.
The hole over your windshield is an untreated stone chip that was just allowed to rust away
Old Jun 28, 2014 | 7:55 PM
toskala112's Avatar
Message appears when driving...I bought the vehicle from bayview auto in Trenton it had about 75,000 on it when I bought it.....driver side hub was covered under manufacturers warranty passenger side was just done with the outer tie rod as well...
Old Jun 28, 2014 | 7:57 PM
toskala112's Avatar
The hole above the windshield seemed like it started from the inside and worked its way out...
Old Jun 28, 2014 | 9:13 PM
Papa Bear's Avatar
There are only 2 things that would make the "low oil pressure" warning sound.
1) Truly the engine is experiencing low oil pressure
2) There is a faulty sensor/switch indicating low pressure when in truth the pressure is fine.
A tech has to find out whether it is #1 or #2...
Did you get a carfax on your vehicle to discover it's history?
Old Jun 28, 2014 | 9:50 PM
Official GM Rep
Hi toskala112,
I’m sorry to hear of the troubles that you are experiencing with your Uplander. Please feel free to contact GM of Canada for further assistance in regard to your concern. Their number is 800-263-3777 Monday through Friday from 7:30 AM until 11:30 PM and Saturday from 7:30 AM until 6:00 PM EST. Please let us know if you have any other questions.
Kristen A.
Chevrolet Customer Care
Old Jun 29, 2014 | 12:12 AM
toskala112's Avatar
Yes a Carfax report was included in my contract...nothing out of the ordinary...no accidents or problems...
