Uplander 2005-2009
Platform: U-Body
Old Jul 29, 2015, 2:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Wheels and Tires
Print Wikipost
BRAKE VIBRATION
Old Dec 27, 2011 | 12:07 PM
  #11
Originally Posted by theeurocar
Any suggestions on maunfacturers of replacement, slotted rotors (I assume for heat dissipation...)?
Welcome to the forum...this is fairly old post...
Vented and slotted rotors can carry there own problems and usually cost more..
but yes its to dissipate heat more quickly.
unless you have done extensive mods for performance I would stick with OEM replacements...
Old Feb 4, 2012 | 1:31 AM
  #12
Tankrat's Avatar
I know this is an old topic, but the best way to get rid of rotor vibrations is to buy the premium/heavy duty rotors from the parts store or online with cermic pads. I do brake hard all the time in AZ and never get vibrations from the prem rotors
Old Feb 9, 2012 | 9:42 PM
  #13
belleaudb's Avatar
Default Brake rotor warpage TSB
Bulletin No.: 07-05-23-003B
Date: April 28, 2009
Subject: Pulsation/Vibration When Applying Brakes (Repair Rotor Variation and Install New Front Brake Shields)
Models:
2005-2007 Buick Terraza
2005-2009 Chevrolet Uplander
2005-2009 Pontiac Montana SV6
2005-2007 Saturn Relay Supercede:This bulletin is being revised to add the 2009 model year and update the labor operations. Please discard Corporate Bulletin Number 07-05-23-003A (Section 05 - Brakes). Condition
Some customers may comment on a pulsation/vibration felt when applying the brakes.
Cause
This condition may be caused by the brake pads and rotors wearing unevenly due to debris.
Correction
Repair the rotor variation and install new front brake shields using the steps below:
<table cellpadding="1" cellspacing="2"><tbody><tr valign="top"><td>1.</td> <td>Verify that the condition is from the front brakes.</td> </tr> <tr valign="top"><td>2.</td> <td>Correct the rotor variation by referring to the Brake Warranty Service and Procedures Bulletin Number 00-05-22-002 or later. Important
Measure Lateral Run Out (LRO), brake rotor thickness specification and document the information on the repair order. Include the warranty claim code and ONLY claim this Special Labor Operation H9725* for this bulletin. </td> </tr> <tr valign="top"><td>3.</td> <td>Remove the front wheel bearing/hub. Refer to Front Wheel Bearing and Hub Replacement in SI.</td> </tr> <tr valign="top"><td>4.</td> <td>Remove and discard the old front wheel speed sensor bracket and old wheel bearing/hub bolts.
<table cellpadding="1" cellspacing="2"><tbody><tr valign="top"><td>5.</td> <td>Install the new front brake shield (1). Important
The wheel bearing/hub bolts must be replaced. </td> </tr> <tr valign="top"><td>6.</td> <td>Install the front wheel bearing/hub. Refer to Front Wheel Bearing and Hub Replacement in SI.</td> </tr> <tr valign="top"><td>7.</td> <td>Repeat this entire procedure on the opposite side.</td> </tr> <tr valign="top"><td>8.</td> <td>Verify that the condition has been corrected.
19167950: Shield Front Brake LH
19167253: Shield Front Brake RH
</td></tr></tbody></table>
coastn
Nov 17, 2014 8:13 PM
greatwhite99
Aug 27, 2011 4:00 PM
bigcar
Apr 29, 2009 11:33 PM
toad305
Aug 1, 2007 1:46 PM
