Uplander 2005-2009
Platform: U-Body
Engine locked after running out of gas
Old Sep 3, 2021 | 3:47 PM
AdventuresNatnKat's Avatar
Default Engine locked after running out of gas
Was on empty, moving van in the driveway. Turned key, tried to turn over, put putted then went dead and security system went nuts. Horn honked and doors locked. Filled it with gas. Now nothing comes on at all in the dash. Turn key and pump won’t even come on. Any way to get it started?
Old Sep 4, 2021 | 7:10 AM
hanky's Avatar
Could it be that you didn't run out of gas, but there is a possible electrical problem?
Check,,,,,,,,,,,,,,means remove clean and reinstall all the ground connections you can see in the engine compartment starting with the battery cable connections.
Fx1971
Apr 28, 2020 2:32 PM
05_Malibu
Mar 15, 2017 2:26 PM
buzz_mn_58
Aug 1, 2011 10:36 PM
guvner
Oct 30, 2007 7:55 PM
tuffgong1003
Jun 16, 2007 12:02 PM
