Uplander 2005-2009
Platform: U-Body
No crank No start
Old Jun 9, 2020 | 9:40 AM
Rkelley5x's Avatar
Default No crank No start
Hey I have a 08 Uplander that wil not crank or start. When i turn the key nothing lights up on the dash but the check engine light. After checking a couple different youtube videos i found myself down by the BCM(in drivers side kick panel). Following the harness from the BCM i found an inline connector under the carpet that runs up to the dash harness and firewall. At this connector i found a melted wire with no insulation left on it. When i disconnect this connector my dash lights back up and i can start the vehicle and it runs but all the abs, brake, & traction control lights are on. Im assuming when this connector is connected its taking down the network. I have a wiring diagram but i cant find this connector to find out what circuit is melted? Has anyone seen something like this?
Old Jun 9, 2020 | 2:48 PM
Try to repair this bad wire. cut out the bad piece and replace it with a piece of new wire. if there is more than one wire then do the same for the other one. follow it back to a good piece of wire to make sure you are connecting it to the right one.
Stevenhuskey
2007 - 2013 (GMT900)
Apr 18, 2023 1:12 PM
Brennan Webb
Feb 13, 2018 8:45 PM
Jwmoore
Feb 8, 2017 10:19 PM
00247
Jan 15, 2013 8:06 PM
lugnuts
Dec 25, 2008 9:20 PM
