Uplander 2005-2009
Platform: U-Body
Rear Spark Plugs
Old Feb 4, 2024 | 11:05 PM
Ping Pong's Avatar
Default Rear Spark Plugs
Does anyone have real world experience of replacing rear 3 spark plugs on a 3.9L Uplander?
I tried rotating engine, and I still could not reach plugs.
I tried to remove Upper Intake, but I can't get access to the rear Ignition Coil Bracket bolt that must come out before I can remove Upper Intake.
There is also a thick harness and power steering lines that block the left Ignition Coil Bracket nut...
There must be a trick, I'm missing - please help!
Old Feb 5, 2024 | 4:55 PM
try charm.li
Old Feb 5, 2024 | 6:45 PM
Ping Pong's Avatar
try charm.li
I did use charm.li (an excellent resource), their directions work well if you have engine out of the vehicle... the problem is the engine is buried and some of the nuts are obscured by thick harnesses that disappear to the back of the engine.... that is why I'm hoping someone who actually worked on the 3.9L would chime in with their real world experience.
Old Feb 6, 2024 | 3:09 PM
Papa Bear's Avatar
Old Feb 6, 2024 | 3:48 PM
Ping Pong's Avatar
The 3.9L engine bay is a lot more buried - which is what causes all the access issues. There is also a thick harness that covers bolts you need to remove ignition coil brackets etc to which then gives you more access and allows you to the upper ntake manifold off.
Old Jun 9, 2024 | 2:15 PM
04colyZQ8's Avatar
I removed the coil and plugs on my 09 3.9l rotated after removing dog legs. Take the coil bracket off with two bolts one on driver side from bottom of engine (I have a hoist), and passenger side take off from top by feel, it’s near the alternator back.
did all three plugs on the firewall side from the bottom
Old Jun 11, 2024 | 1:10 PM
haze5736's Avatar
I also replaced the rear plugs from under the car a couple months ago. I did not loosen the engine mounts or pull the engine forward. I did it in my gravel driveway on ramps. I was laying on my back reaching up. It was surprisingly comfortable for me to work like this. I have long arms so maybe that helps. I also have skinny arms and hands/fingers. I can't remember if that would make a difference. It probably does.
msv9535@yahoo.com
Aug 26, 2018 4:37 PM
hopinjon
Colorado
Feb 13, 2012 12:23 AM
Bru7al17y
Sep 5, 2010 4:57 PM
catill
Aug 30, 2010 11:07 AM
lightGear
Colorado
May 21, 2007 9:36 PM
