Uplander 2005-2009
Platform: U-Body
Rear tires wearing funny
Old Aug 11, 2009 | 7:29 PM
minnuplander's Avatar
Default Rear tires wearing funny
I have an 05 uplander. The rear tires are wearing on the inside with high and low spots so I am getting serious noise. The axle is straight so I was told that the rear tires cant be aligned. Is this right? The tires appear to be tipping in on the top. I guess i am wondering what can be done to fix this. Or what the problem can be. I dont want to put new tires on until i can fix this. Please help!
Old Aug 11, 2009 | 9:42 PM
DeeZ's Avatar
Ride of the Month
August 2009
I'm not too familiar with your vehicle but if it has a strait axle than no you can't align it. Fortunately alignment isn't the reason for your tires are balding like they are, make sure your psi is right and get your shocks checked. Also, when was the last time you rotated your tires?
Deez
Old Aug 11, 2009 | 11:07 PM
EvansBlue's Avatar
Its a FWD with an independant rear suspension. All 4 wheels can be aligned.
Old Aug 12, 2009 | 9:02 AM
Papa Bear's Avatar
Does it have independent rear suspension ?? .....
Old Aug 12, 2009 | 1:13 PM
DeeZ's Avatar
Ride of the Month
August 2009
Didn't that answer you're question? lol
Deez
Old Aug 12, 2009 | 8:57 PM
Papa Bear's Avatar
Yes, it answered it... but was it the correct answer ??
Old Aug 12, 2009 | 10:04 PM
EvansBlue's Avatar
To be more specific, it has a trailing arm rear suspension which is semi-independent because it has a stabilizer bar.
I don't see why it can't be aligned.
I have seen cases before where the stabilizer bar was bent because a trucker decided to use it as a place to hook his chain on the car-carrier and if its bad enough, alignment won't help. Thats your worst-case scenario.
Old Aug 12, 2009 | 10:28 PM
Default sorry
Sorry, It has a straight axle. It is front wheel drive. It does not have the independant rear suspension. The psi is good. The tires are goodyear integritys. The wear starting happening at about 8000 miles. Discount tire said my rear is out of alignment. How do you fix that. Will worn shocks cause that.
Old Aug 12, 2009 | 11:01 PM
EvansBlue's Avatar
Not so. It most definately has a Semi-independant rear suspension. What you call the axle is most likely the stabilizer.
See these links, they all say that the FWD model has a Semi-Independant trailing arm rear suspension:
http://www.automotive.com/2005/12/ch...e-braking.html
http://www.automobilemag.com/am/2005..._handling.html
http://www.motortrend.com/cars/2005/...ons/index.html
http://www.auto123.com/en/chevrolet/...rid=1051204501
Old Aug 13, 2009 | 9:09 PM
Papa Bear's Avatar
Patiently waiting to hear how this turns out.........
someone "in the know" will step in shortly and put this to rest.
