Venture 1997-2005
Platform: U-Body
02 venture won't crank no power to coils
Old Mar 17, 2025 | 10:49 PM
Toxik1989's Avatar
Default 02 venture won't crank no power to coils
So.apparently from.what I've be3n seeing.
ventures = adventures...gees
.new heads,intake, fuel pump/filter,oil, Coolant,cam shaft sensor, battery, few hoses, pvc valve, motor.mount( bottom not.struts or.trans) i thi k that's all..soo fixed heads got it going..it idled rough died when idling.or coasting with no acceleration..u can tell ive been.at.it for few months now.it would slightly jerk,skip,twitch..w.e the lights would slightly dim
.and bog down and die.
if that happened..GL.. cranking it bak
.I found cycling gears and moveing motor around helped it recrank..So assumed mount..I could rock motor forwards and bk by 2 fingers
Replaced mount and .cam sensor
No codes
But.coils.arent getting power. Tracked.it.to.that much.
It will engagestarter but not.crank..only codes that have appeared from start to finish
Evap
Misfire cyl 1
cam shaft position sensor(off and on .randomly)
figured had to.do.w.motor.alignment henc3 th3 mount.
As
of last code was th3 cam.shaft..I just replaced and clear3d..no codes..but no power to coils
If need more.info feel free to email incase I'm slow responding...
A.maples1989@gmail.com
Thanks
Charlie Bailey
Captiva
Apr 4, 2024 3:44 AM
mikeu_sc
1988 - 1998 (GMT400)
Nov 21, 2018 2:04 PM
Wmortell
Aug 18, 2017 1:24 AM
4.3vortech
Oct 22, 2016 1:52 AM
