Venture 1997-2005
Platform: U-Body
Old Jul 29, 2015, 6:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Help on inner tie rod end
Old May 30, 2011 | 9:05 AM
Avenger's Avatar
Default Help on inner tie rod end
I am planning on replacing the inner tie rods on my friends 2003 Venture. I'm not real familiar with front wheel drive setups. I have done some research and the job looks fairly easy as long as you have the right tool to remove the inner tie rod. Is there anything I need to watch out for when doing this job? Thanks!
Old May 30, 2011 | 8:59 PM
tuffy's Avatar
just did mine this weekend. your right you just need the special tool. and an alighnment afterwords.also check the outers while your at it.
Old May 31, 2011 | 8:21 AM
Avenger's Avatar
Thanks Tuffy.........As it turns out, we only had to replace the outer tie rod ends. The inners felt pretty solid. Thanks for the reply. ( I'm going to get the tool anyway because I know I'll need it sometime in the future.)
citygirl
Jul 20, 2010 8:21 PM
hfb1957
Aug 12, 2008 8:22 AM
jonmad99
Jul 2, 2008 2:24 PM
blaineo
Jul 20, 2007 4:41 PM
smitty6
Aug 7, 2006 8:31 PM
