Venture 1997-2005
Platform: U-Body
P0327 Low voltage to sensor
Old Apr 18, 2022 | 6:20 PM
BigJoe79's Avatar
Default P0327 Low voltage to sensor
I have 2001 venture who keeps throwing code p0327 low voltage to sensor. I have changed the knock sensor and pigtail to sensor and keeps throwing code. Any help would be great.
Old Apr 21, 2022 | 2:06 AM
Photon440's Avatar
You've done what I would have tried - suspect the sensor was faulty and change it out. Other than a hidden frayed wire or bad connection between the PCM/ECM, it's possible that the PCM/ECM itself is out of order. (but that is usually less likely the cause). To be sure that the sensor that you just changed isn't the culprit, you can test it like this:
ps. - Welcome!
Ethan Hooper
Jan 18, 2020 12:31 AM
snowman2003
Mar 1, 2015 2:07 PM
wayne220
Jun 28, 2010 4:31 PM
USR_BS
May 27, 2010 10:46 AM
randyrt
Sep 1, 2009 9:30 AM
