Venture 1997-2005
Platform: U-Body
Signal Lamp Problems 2001 venture van
Old Apr 29, 2013 | 9:16 PM
rjsp's Avatar
Default Signal Lamp Problems 2001 venture van
When the left blinker was switched on, and the brake applied, the blinker would flash faster, the dash directional arrows both start flashing, and both rear brake lights were flashing dimly. The right side lamp was shorted inside at the bottom due to water and rust. both lamp black ground wire connections were corroded . I cleaned up the rust inside the housing, purchased good connectors for both lamps from the wreckers, soldered and heat shrinked them in, and the lamps are now working correctly. On a side note I originally tried to clean up and repair the connecters without parts, after a few days the auto headlamps stopped working, no dash lights, no tail lights park lp fuse under hood was blown, chime would engage when drivers door opened, what I found was at the bottom of the right tail light there is a small tab that got bent over when I cleaned the rust up causing a short, after removing the little tab, replacing the wire connecters, replacing the fuse, everything returned to normal.......
Attached Thumbnails Signal Lamp Problems 2001 venture van-dsc01406.jpg   Signal Lamp Problems 2001 venture van-dsc01404.jpg
fish_oil
Jun 12, 2020 10:00 PM
royschevy109
Mar 10, 2008 6:17 PM
dkh96825
Feb 21, 2008 7:44 PM
maddhatter1394
Jan 10, 2008 8:15 AM
flyer00
Oct 28, 2007 10:09 PM
