Chevrolet Malibu
orifice tube
Old August 12th, 2012, 8:02 PM
tthreat's Avatar
Default orifice tube
Im trying to locate the orifice tube on a 2006 malibu anybody know where it is?
Old June 23rd, 2016, 7:23 PM
James Rupinski Sr.'s Avatar
At firewall on high pressure line, you'll notice flare in pipe.
Old June 23rd, 2016, 9:53 PM
pretty sure 06 mailbu do not use orfice tubes. check your condenser...if it has a cylinder next to it, receiver dryer...orfice tubes are not used.
the metering device would then be a thermal expansion valve located where both high and low a/c lines connect at the fire wall.
Old June 24th, 2016, 9:40 AM
Tech2, I just removed orifice tube (NOT ORIFICE TUBE, FILTER) to check for debri. Replacing compressor next. Made ever separation possible from condenser back and wound up at firewall. Lower line has flare and orifice tube going to high side. At end of week will supply pics when replacing new orifice tube and comp.
Old June 24th, 2016, 1:54 PM
what engine size do you have? I looked up service info for a v6 either 3.9 or 3.5L IIRC.
I believe you. pics may help the op
Old June 24th, 2016, 3:49 PM
2.2 L vin# fourth letter Z , 2006 Chevy Malibu LT 4 dr Sedan
Old June 27th, 2016, 12:30 PM
Pics
Last edited by James Rupinski Sr.; June 28th, 2016 at 1:18 PM. Reason: This system DOES NOT have an orfice tube. What is showing in picture is actually just a FILTER...
Old July 3rd, 2016, 2:00 PM
can't ask for more than that!
keelklan
July 20th, 2021 9:40 PM
tom5170
November 30th, 2010 11:42 PM
dan32
July 3rd, 2010 3:14 PM
andyjf80
April 18th, 2010 2:51 PM
samger2
August 7th, 2009 12:47 PM
Quick Reply: orifice tube
