the disc installed is not a MAP DVD on 07 Taheo
Hi all , i just got this SUV few week ago,the NAV was working fine, but yesterday when i start the car it said (the disc installed is not a MAP DVD), i try to clean and restill the DVD for few times still don't work,
i help please
i help please
Nav dvd
Is it a 'real' DVD or a copy?
pull it out and does it look like a movie DVD (shiney grey/silver) or is it bluish purple on the bottom and say DVD+R DL on it?
if you don't copy it right, it won't work... and will say that.
Ebay has tons of real DVDs...
to starz nav problem
I had the same problem with my nav. It worked then it didn't so I pulled the radio out. Put it back in the next day and it started working again. But before u do that disconnect the battery and let it sit for 45mins to an hour then turn it on and check.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I am sorry you have had problems with your navigation disc. If you continue to have problems with your disc, please contact the Navigation Disc Center at: 1-877-628-3472.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
Louis
GM Customer Service
I took the radio out, unplugged it, and let it sit for a while. I hooked everything back up and still the same. I already tried the dvd cleaner. It got stuck inside and when I finally managed to get it out, it still didn't work.
How often do these navigation systems go bad?
Scoobysam
March 29th, 2015 9:30 AM
technicauto
May 4th, 2011 5:14 PM
biglg
February 5th, 2007 11:38 AM
