88 Cheyenne k1500 4.3L no start no scan
Old Jul 22, 2021 | 9:02 AM
  #161
Chevy frustrating me's Avatar
I almost get 5hg if I take the reading from pcv hole on front of tbi without map sensor tube plugged in. It keeps backfiring through tb. I keep reading back through all your great suggestions. I dont understand how it started one time but never again.
Old Jul 22, 2021 | 6:30 PM
  #162
Gumby22's Avatar
Is it cranking the same way as it did in the videos you posted? Where it sounds like it’s trying to start but never actually does? If so it’s possible the reason is the dry cylinders are firing but the wet cylinders aren’t. It may be helpful to test for spark at the wet cylinders to make sure the plugs or wires aren’t having problems.
Not sure on why there’s different vacuum readings depending on the port used - the MAP sensor, brake booster and PCV port are all connected to full manifold vacuum. I’ll have to think on that.
Old Jul 24, 2021 | 1:23 PM
  #163
Got it running she smoking like a chimney from the restore i put down cylinders lol
Old Jul 24, 2021 | 1:52 PM
  #164
Strange part is only 3 of 6 plug wires are plugged into spark plugs wth?
Old Jul 24, 2021 | 1:56 PM
  #165
I forgot to plug all the passenger side plug wires back into motor? So weirded out atm
Old Jul 24, 2021 | 3:45 PM
  #166
Gumby22's Avatar
So you just needed to make sure the plug wires were fully seated and it started? Awesome! I’ve forgotten to hook them up several times during diagnosis.
A thin layer of dielectric grease helps them seat on the plugs and cap.
Old Jul 24, 2021 | 3:55 PM
  #167
It never would start with all 6 plugs wires on so I was about to pull motor or junk it. So I put restore down each cylinder and only hooked drivers side plug wires back up by accident. Truck started it ran ruff and then when I was going to put valve cover back on realized oh **** lol now with all 6 wires on she runs and much better.
Old Jul 25, 2021 | 5:08 PM
  #168
Gumby22's Avatar
Good deal. I totally understand the relief that comes with a seemingly never-ending project/repair finally has an end in sight. At work I get anxious even when I expect a repair to take an extended amount of time.
Does it respond well to throttle? Any popping or chugging/hesitation?
Old Jul 31, 2021 | 12:39 PM
  #169
Just waiting for valve covers. I will update once I get them.
Old Jul 31, 2021 | 2:07 PM
  #170
I never would have got it running without your help so thank you very much again. Next is Frame repair and interior.
