rear differential still leaking after gasket replaced
Old Sep 26, 2021 | 3:47 PM
revmhall's Avatar
Default rear differential still leaking after gasket replaced
98 k1500 suburban rear differential was leaking so I removed the cover, drained the oil, replaced the gasket, reattached the cover, & filled with gear oil. Tightened bolts to 30 lbs with torque wrench. And….still leaking. Leaking worse! What did I do wrong? Any advice, help?!?! Used
FEL-PRO Axle/Differential Gasket RDS55028-1
Old Sep 26, 2021 | 4:03 PM
kevinkpk's Avatar
Did you use a full synthetic gear oil? Full synthetic oils require a viton gasket/seal. If this is the case, and I do not know that fel pro, might be your issue.
Old Sep 26, 2021 | 8:32 PM
revmhall's Avatar
Default used conventional STP gear oil
Thank you for the reply. I appreciate the help. I did not use synthetic oil. Used this STP gear oil. Any other thoughts? Anyone out there think it is a bad gasket or have another recommendation?
Old Sep 27, 2021 | 9:21 AM
post a pic of the leak area.
if leaking from the cover....did you clean the mounting surfaces? if from the pinion or axle seals...if the diff vent plugged?
Old Sep 27, 2021 | 12:24 PM
revmhall's Avatar
Default leak pics
Thanks for the reply tech2. Here are leak pics. Seems to be coming from the bottom. I did clean the surfaces, used parts cleaner and also scraped off the old gasket remains. Seemed more like a rubbery goo than a true gasket. I read elsewhere to only scrape with a plastic tool. I did use a metal scraper and a screw driver. Did I damage the cover? If so how to remedy? Anyone think I should try Blue Devil Oil Stop? Redo the gasket with a sealant gasket maker as well?
Old Sep 27, 2021 | 1:23 PM
kevinkpk's Avatar
You don't want to scrape on a machine matted surface which is not the cover. If it's leaking around the threads, I might suggest a metal washer and O ring.
Old Sep 27, 2021 | 4:00 PM
drain the diff; catch and save the fluid. clean the surface and dry wipe with brake cleaner. throw the gasket out and use rtv. I "like the right stuff"
Old Sep 27, 2021 | 4:01 PM
Rednucleus's Avatar
May be an optical delusion but looks to me like the cover is bent outward where it's leaking - maybe got pried open there??
Old Oct 4, 2021 | 1:12 PM
revmhall's Avatar
Thanks again to all who have replied. I am curious about the possibility of a bent cover. I don't think it is, and I know I didn't have to pry hard to separate it when I drained it the first time. I think I will drain it and use RTV...hopefully that will settle the problem. Anyone advise against replacing the cover?
Old Oct 4, 2021 | 1:30 PM
kevinkpk's Avatar
Place to cover on a flat surface, sets flat it's good.
