stock fuel gauge VS aftermarket fuel gauge
Newbie here...I have a 1998 chevy cheyenne k3500 4x4 dually flatbed with the 7.4L. The fuel gauge in the stock cluster doesn't work so I put another used cluster in and still doesn't work. Before I changed clusters I installed a new fuel pump/sender in the fuel tank. Has anyone had this problem?
Also, I was thinking of getting an aftermarket fuel gauge and just install it in a pod somewhere but cannot find the correct Ohm rating for the stock fuel tank sender. I was told it's a 10-250 ohm but couldn't verify. Of course I'd rather find the problem and use the stock gauge/cluster. I don't want to spend $700 for a new cluster. any help would be GREATLY APPRECIATED!
Thanks Kevin I'll try checking the wires for a ground issue. and will double check the fuses again. Do you know how I can verify the ohm ratings without pulling the sender? I guess I could go check a new one out of the box at the parts store lol. But somebody should be able to tell me what the Ohms are for those stock fuel senders right? I looked for the specs (Ohms) on the internet but couldn't find anything. I could try calling a few aftermarket fuel gauge makers or Summit etc.
Thanks again
Thanks again
Thanks again
Thanks again
wscottman
Oct 27, 2017 12:50 PM
