2004 5.3 Silverado won't read emissions
Old Mar 12, 2016 | 2:13 PM
mikekozura's Avatar
Default 2004 5.3 Silverado won't read emissions
My son's Silverado won't fear the modules at the garage for the emissions test. We did all the go but a 100 miles on it thing. PCU or wire ????
Old Mar 13, 2016 | 12:47 PM
ToooTall1's Avatar
Default emission
Check your cigarette lighter fuse
Old Mar 13, 2016 | 1:29 PM
cleveland63b's Avatar
does the scantool power up?
Old Mar 13, 2016 | 1:41 PM
mikekozura's Avatar
Yes our hand held scanner reads. And the OBDII fuse is good.
Old Mar 14, 2016 | 7:31 PM
so it powers up but doesn't read the ECM? Do you have access to any other modules or a different scanner?
Old Mar 15, 2016 | 7:23 AM
mikekozura's Avatar
Our hand held scanner reads but when I take it to the garage for emissions inspection it doesn't read the modules it needs for the test. I guess the ECU is not storing them
Old Mar 17, 2016 | 7:21 PM
I don't really understand what you're getting at I guess. My guess is you need to try a higher end scanner
Old Mar 26, 2016 | 7:28 AM
maddog0324's Avatar
I'm having a similar problem with my '04 Silverado LT 5.3L. The I/M monitors will reset after reading with a code scanner. Someone suggested that the nonvolatile memory isn't retaining the information for the I/M monitors. Has anyone heard of this?
Old Apr 15, 2016 | 11:38 AM
maddog0324's Avatar
Update:
It turns out that the ECM was bad
