2008 5.3L Oil issues
Old Apr 23, 2020 | 6:23 PM
  #11
Noodles's Avatar
Originally Posted by bdbrown66
... but essentially it said that the AC Delco PF48E filter, which is what is specified in the manual, can cause low oil pressure indications. If so, it should be replaced with the UPF48R filter. I looked under the truck and could see that it was a blue oil filter, so I suspected that it was probably a PF48E. A little further research indicated that the Mobil M1-113 filter was identical to the UPF48R filter, and was available at my local AutoZone store. So I bought 6 quarts of Mobil1 5W-30 and an M1-113 filter and did an oil change. Lo and behold, the oil pressure went right back up to 43+ on a cold start, 40 driving down the road, and 30-35 at idle. Problem solved, to my great relief. Good luck with yours!
Sorry for the late reply. I decided to do what you did and just do the oil change because my truck also had the PF48E. I used 6 quarts Castrol Edge 5w-30 and a Fram XG10060 filter. When I started the truck the pressure went up to around 55 👍🏻 After it’s warmed up stays around 40 unless my RPM is around 500 (usually at a stop with brakes on) then it will drop to around 20. I’m calling this one solved for now. Thanks for the info!
Thomas Badger
Mar 11, 2020 6:40 PM
Jose Sanchez
May 19, 2019 11:54 AM
MarlinL
2007 - 2013 (GMT900)
Mar 8, 2019 5:46 AM
Clemens
Feb 10, 2018 1:44 PM
Snuggyworm
Sep 19, 2016 12:07 PM
