2012 Chevy 2500 6.0 no crank no start
Old Jul 19, 2024 | 4:13 PM
Rockman 101's Avatar
Default 2012 Chevy 2500 6.0 no crank no start
Dash lights radio blower fan all work. Turn the key nothing. Engine does turn over when jumping starter relay. Fuel pump doesn't kick on either. Has a new ECM that has been programmed. Checked all grounds sanded and cleaned. Fully charged new battery. Checked all fuses and swapped around relays. Tried new ignition didn't help and new keys. No idea what to check next. Thanks for any advice
Following codes pop up on scanner
P0123
P0223
P0135
P1682
P0523
P2176
Old Jul 25, 2024 | 10:27 AM
Anything?
Old Feb 27, 2025 | 7:24 AM
Raywhitetattoo's Avatar
Default 2012 Suburban 2500 hit bump all hell broke loose
2012 Suburban commercial 2500 6.0 gas 4x4
seems like after hitting a substantial bump, traction control light came on. Message reading service traction control as well as service stabilitrac reading on dash. Immediately transmission would not shift out of 1st. Got it home and noticed the shift indicator bar under PRND etc. was no longer on. When shifter is physically in reverse, reverse lights also do not work. After initially shutting the engine off, it no longer cranks at all. I do hear the starter relay clicking but no cranking at all. Any ideas?
2022 Lexus ES First Look (Sporty AND Economical?)
The 2024 Lexus LC 500 Convertible is finally PERFECT
2020 C8 Corvette Exhaust Capture
2021 Mach 1 Review |||  Best 5.0 Mustang Ever???
Subscribe
Reply to Thread
Back to Subforum
View Next Unread
Engine RPM-related harmonic noise from passenger-door rear speaker
1/1
Johnsilverado
2007 - 2013 (GMT900)
Mar 2, 2025 6:05 PM
Jmpks70
Jan 16, 2022 5:52 PM
Hagan
Dec 29, 2021 7:57 PM
LHP
Sonic (Aveo)
Nov 11, 2017 7:00 AM
phlyntstone
Dec 10, 2005 4:17 PM
