A door locking mystery....
I just purchased a 2011 Silverado 1500 and I noticed that I cannot lock or unlock the doors using the button on the door. This is the same on the driver and passenger's side. However, I can lock and unlock the doors with the key fob. Also, when I start the car and put it in drive, the doors lock, and when I shut off the car the doors unlock. Hmmmmmmmm
Otherwise, all the fuses for the door locks are in the instrument panel fuse block at the left end of the dash. They are labeled as lock or unlock 1&2 depending on the setup. You’ll also want to check the fuses labeled PDM & DDM as these supply power for the door switches.
Gumby, I do have bucket seats in the front and automatic mirrors. I have gone through all the fuses and they all ohm out. Please provide me the wiring diagram, so I can pint point the difference between the key fob locks and the door locks.
Doug, I was trying to convey that the locks work, when I put the truck in drive or park, and when I press the door lock/unlock on the key fob. What does not work is when I press the button on the door to lock/unlock the vehicle. Both driver and passenger doors do this.
Have you installed any accessories that required splicing into the dash harness? What about some kind of monitor that plugs into the OBD port? What about a phone charger or GPS? For about the past 20 years, GM has had an on-going service bulletin about aftermarket accessories interfering with normal vehicle functions and the effects can vary greatly. The easiest test for this is to just unplug the accessory and see if normal operation returns.
The wiring diagram is below. It would appear this is a BCM problem as the door switches are just inputs and the BCM controls the locking/unlocking of the doors. That said, one weak point in all vehicles is the section of the harness that passes through the boot between the door and cab. It’s unlikely that both door harnesses would fail at the same time, but if the driver door failed first and the passenger second, maybe the PO didn’t know because they never used the door buttons; or maybe they ignored the problem. If you find the harness to be at fault, I recommend just getting the replacement harness from GM because usually one or two wires going open means the rest aren’t far behind.
polpower
Aug 19, 2013 10:42 PM
