2014 5.3 P0300 AFM delete done
Old Jan 22, 2023 | 6:02 PM
Crashgls's Avatar
Question 2014 5.3 P0300 AFM delete done
I am at a loss. 2014 chevy 1500 5.3. Codes P0300 P075 P0157 and P0219A. I have changed plugs wires coils Injectors did the AFM delete with new cam and lifters. Turned AFM/DOD off with HPtuners. I have verified it is off. Still throws the same codes. Compression is 125 to 135 in all 8 Cyl fuel pressure is 50. What am I missing? Help please.
Old Jan 23, 2023 | 3:05 PM
oilcanhenry's Avatar
I am not all that familiar with AFM motors, but even so, 125 to 135 PSI is pretty low compression. In a non-AFM gasoline engine compression ratio 150 to 175 is normal, as is a fuel pressures of 55-to 62 PSI for the injectors to operate properly. In a normal engine you don't want more then 15% difference compression between the cylinders.
jer123
2007 - 2013 (GMT900)
Dec 23, 2022 3:26 PM
Gpetrie
Nov 1, 2022 1:03 PM
Hokiefan
2014 - 2018 (GMT-K2)
May 12, 2021 8:39 PM
ProR
Feb 4, 2021 1:55 PM
meyz37
Jan 21, 2018 11:59 AM
